주요 콘텐츠로 건너뛰기
6MB 공유 L3 캐시 2.0GHz, 2.3GHz, 또는 2.6GHz 쿼드-코어 Intel Core i7 프로세서 (Turbo Boost 최대 3.8GHz).
580 질문 전체 보기
The battery A1494 is compatible with the model A1398 of MacBook Pro?
In the website, I have only see the model A1494 for the MacBook Pro 15” Retina Late 2013. But for my macbook, it is the model A1398.
I want to know if this model is compatible before buy this battery.
Thanks you
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 5
댓글 1개
These are all of the A1398 systems
댓글 달기
답변 4개
가장 유용한 답변
Well you have selected the wrong machine:
This appears to be your machine:
Apple MacBook Pro "Core i7" 2.3 15" Retina 2012 Specs
Identifiers: Retina Mid-2012 - MC975LL/A - MacBookPro10,1 - A1398 -  2512
Here’s the battery for your machine:
COMPATIBILITY
  • MacBook Pro 15" Retina A1398 Mid 2012 to Early 2013
SPECIFICATIONS
Model #:
A1417
MacBook Pro 15" Retina (Mid 2012-Early 2013) Battery
MacBook Pro 15" Retina (Mid 2012-Early 2013) Battery 이미지
상품
$79.99
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
Thanks you so much for the bad advise, The battery A1417 isn’t compatible. And know I have to resend the battery...
Sounds like you have a bit of confusion! What is your exact model
MacBook Pro's
The A1494 is the ID of the battery not the system (A1398). Once we know your exact system we can get you lined up with the correct battery.
댓글 달기
@mayer is right and @jewel_g the iFixit kit is best if you want quality parts…….
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
Welp... thanks for the note. I'll keep that in mind
your welcome (big fat cheesy smile)
댓글 달기
Yes, this battery model is compatible with the Macbook Pro Model you mentioned.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Are you trying to buy a new battery? If so, you’re out of luck, as far as I can see. Try ordering one from Amazon, but before you hit order, check the reviews to see if it’s reputable.
해당 답변은 도움이 되었습니까?
점수 -1
댓글 8개:
Why Jewel ? I want to buy a new battery and I think the iFixit kit is good
Well, I never noticed iFixit sold one. If you want to , go with that. Good luck!
Were are you looking that you came to that conclusion?
IFIXIT is one of the larger sellers of replacement batteries.
Amazon. (Laughs nervously)
Take the rose colored glasses off ;-}
IFIXIT does not sell directly on Amazon. Amazon is not where you find quality parts, mostly cheap knockoff junk!
댓글 3개 더보기
댓글 달기
귀하의 답변을 추가하세요
timothee.thouvenot 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 21
전체 시간: 2,884
