주요 콘텐츠로 건너뛰기
컴퓨터 수리 질문에 대한 해답을 찾으십시오.
21220 질문 전체 보기
windows no boot past windows
i have seen this with a latitude E6400 , an inspiron 1501, and now an optiplex 960 sff
it boots past bios , it will insall windows on hard drives with installation disk, but when booting to windows right before it goes to the login screen the desktops and laptops restart
i have bought a new motherboard for the latitude E6400 and after replacing the motherboard it was completely fine
pls help
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 4개:
Is the CPU fan properly installed and operating ?
yes , it does
in such scenarios main issue is loose connection and faulty system fan. Please check and try again
i will double check all circuitry later on today
댓글 달기
답변 2개
Thermal paste on CPU? It could be overheating right as it hits login.
Try booting into safe mode. If it’s Windows 7, per the tag, than hold down f8 as you boot.
Good luck!
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
ill try that
Here is a link that has the details if you need them:
https://www.windowspasswordsrecovery.com...
Check all the fans, RAM, and hard drive connections as well.
Good luck
댓글 달기
it could be due to faulty hardware or software,you try this guide on How to Fix Windows 10 Keeps Restarting issue.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Brayden S 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 74
