주요 콘텐츠로 건너뛰기
13.3" ASUS i5-4200u HD Tablet
12 질문 전체 보기
Replacing ASUS T300 Chi micro USB port
When plugging in the ASUS USB dongle I use with my ASUS T300 Chi , a couple of days ago, I saw a small spark (I wasn’t sure I’d seen it it was so small and quick) and then I found that the computer stopped recognising anything I plug in. To make sure the problem is with the port and not the dongle I tried plugging in devices I usually plug in directly using micro USB to micro USB cables, still nothing. Just plugging in the dongle would normally have resulted in a beep.
Is it feasible to replace the USB port?
If so, where to I find the part? I’ve looked online and haven’t found something I am confident would be the right part.
https://en.accessoires-asus.com/dock-boa...|l
https://www.ebay.co.uk/i/332851194760?rt...
The computer is a little over three years old and I hope I don’t have to change it yet!
Thank you
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 1개
Did you ever get it fixed? Please let me know…..
댓글 달기
답변 2개
가장 유용한 답변
To get at the motherboard, you will need to remove the touchscreen display. Since this assembly is literally glued on and the metal back has no give, it is extremely difficult and beyond most DIYers to remove it without destroying it. The glass is very thin and cracks easily. I recommend professional repair.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Is the non-working micro USB port located on the docking module (lower part), or is it the one on the upper part - the “tablet”?
As said above, it will be hard for most DIYer to replace the micro USB port on the “tablet”, but it’s quite easy to replace it on the docking module. To gain access to the charging dock board do this:
  1. Remove 4 rubbers on the bottom case
  2. Remove 10 screws on the bottom case
Here is the original part number for the logic board (motherboard) of the docking module: 90NX00B0-R10030
One of these (used) is currently available on eBay: https://www.ebay.co.uk/itm/302658111849
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Nanouchette 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 15
전체 시간: 1,422
