No display and no backlight
Hi,
I’m have problem with my Early 2013 MacBook Pro it has no backlight.
Tried with knowing good display, no image at all on external display.
Backlight Fuse working fine, but there is small IC chip shows small burning
좋은 질문 입니까?
Can you give us some background information on what happened to the system to start with.
To be clear you don't see anything on the external display
Dan 의
Suddenly display goes off and not respond
Tried reset SMC and PRAM
Checked Backlight fuse is ok with Buzzer
Tried with knowing good display issue still occurs ?!
Tried with External there is signal and working normally on external Display!
as you can see in pic , like burning on this crystal iC !!
Mohamed Ghaly 의
