주요 콘텐츠로 건너뛰기
The 6th-generation Surface Pro, released in October 2018. Available in platinum and black. Model number: 1796.
Can you upgrade the ram on the Surface pro 6?
i was asking to see if i can upgrade the ram on the Microsoft surface Pro 6?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 달기
답변 3개
선택된 해법
The Surface Pro design includes RAM that’s soldered to the motherboard, and so without major “gut renovation” this cannot be accomplished.
이 답변이 도움이 되었나요?
점수 4
댓글 달기
You can’t add RAM. But that might not be your problem. You’ve probably maxed out your hard drive, like my wife, and so the computer is bogged way down and slow. On the back of the case, under the FLAP, there is a micro-SD card slot. You can put as big a card as you want in there. I just put a 256gb micro sd card, which doubled the storage for $50. This, coupled with deleting useless apps and files, should make it run faster. When you’re out of RAM, the computer uses mass storage for “Swap files”. This is why this works.
이 답변이 도움이 되었나요?
점수 2
댓글 2개:
Make sure it's fast though. I bought a SanDisk Extreme with 400GB on Amazon because my drive was always full (Its always on discount). Strangely, since I got it I now somehow got plenty of free storage on my C: drive and don't need it after all, but if I want to load Android on my Surface sometime again I should have no problems with partitioning my storage ^^
How can i do that ?
댓글 달기
The RAM is soldered to the motherboard. So, it would be extremely difficult to upgrade.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
how difficult exactly? are there any guides online
댓글 달기
답변을 추가하세요
Marwan Mohamed 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 29
지난 30일: 129
전체 시간: 32,048
