주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
no display on iPhone 6
hey guys, i replaced screen/digitizer on iphone 6. all good. i carefully put it into a REALLY tight cover. all ok. few days later i had it out to show that cover. that night was in a hurry and kind of mashed it into that cover. never lit up again. it had a very dim light, no display, just very dim. i ordered another screen/digitizer but still the same. this cover is very good, just really dam tight getting it in. what could i have done to disconnect this display.?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Unless the cover is so tight it can bend the iPhone housing, it might be just a coincidence too. When lifting the connectors for replacement it may happen to damage components surrounding them. Issue might be related to the backlight circuit as well as a damage to your new screen. If you still have around the old one I’d try the replacement to check first if it’s a screen damage. If it’s not a screen damage it would probably be on the board itself and would require microsoldering skills.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
john 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 33
