주요 콘텐츠로 건너뛰기
6s와 유사한 하드웨어 사양의 4-inch iPhone은 2016년 3월에 출시되었습니다. 16/64GB 저장 옵션 및 은색, 스페이스 그레이, 금색 또는 로즈 골드로 제공됩니다. 모델 A1662 및 A1723.
1049 질문 전체 보기
Why my camera and flashlight doen't work?
After a drop, i replaced the screen and i noticed that back camera, front facing camera and flashlight don’t work anymore. But if i unplug the back camera the front faceng begin to work. Is it possible thah after the drop, back camera damaged and that issue conflict with working front camera?
Thank you so much and sorry form my bad english
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 2개
선택된 답변
Yep, it is most likely that the rear camera is causing a short circuit which drains the power on the camera circuit causing both cameras, including the flash module to stop working.
Replacing the rear camera should fix the problem.
iPhone SE Rear Facing Camera Replacement
iPhone SE (1st Gen) Rear Camera
iPhone SE (1st Gen) Rear Camera 이미지
상품
$24.99
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Thank you very much, i’ll replace rear camera and i hope should be fine.
댓글 달기
Just ran across this. My iphone SE slipped out of my bag while riding a motorcycle at about 35 mph going to class. It landed in the middle of the street (double yellow lines) and sat there for about 4 hours in the hot sun before I noticed. The road wasn’t busy, but I know that two rigs pulling trailers past it 4 times (one I drove for CDL practice). Lucky it wasn’t flattened and still was functional after laying on the asphalt in 90 plus heat. The screen cracked, but that is expected. Besides the screen, I noticed neither camera or flashlight were working. I’m taking a chance and ordering the back camera and a cheap tool kit to see if this solves my issue.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Emanuele Amantia 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 10
전체 시간: 455
