주요 콘텐츠로 건너뛰기
2010년 중반기 모델 A1278 / 2.4 or 2.66 GHz Core 2 Duo 프로세서
794 질문 전체 보기
CPU Panik?! MacBook not booting. Stuck on loading screen. With error
Hey there,
i have a macbook Pro 2010 13” with an Error massege popping up on start up.
It chimes and everythink looks pretty good, but it wont boot up.
I am aware of the 2010 GPU kernel Panic issue but I tought its just the 15” Macbooks. And this seems to be something different?
Thanks for your help. Pease üt-
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
You have a page fault condition, this is when you either have a RAM or HD problem.
I would take the time to clean the memory module contacts and reseat them. In addition I would reboot under the recovery partition so you can run Disk Utility to check the drive. I would look at replacing the HD SATA cable and the drive with a larger one.
해당 답변은 도움이 되었습니까?
점수 0
댓글 7개:
Thanks for the answer i cleaned the cntacts with alcohol . i am trying to start it from a usb stick. is the image corrupt? Still not working...
What is the bootable USB drive doing?
Are you sure it's the boot drive?
yes i am trying to run the install from it. and i choosen it via alt on boot
the error is not allways displayed most of the time it just freezes
Replace the RAM: 204-pin PC3-8500 (1066 MHz) DDR3 SO-DIMM's
댓글 2개 더보기
댓글 달기
귀하의 답변을 추가하세요
Niklas Jakob 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 2
전체 시간: 228
