주요 콘텐츠로 건너뛰기
모델 A1502 / 4MB 공유 L3 캐시 2.6 GHz (Turbo Boost 최대 3.1 GHz) 또는 2.8 GHz (Turbo Boost 최대 3.3 GHz) 듀얼-코어 Intel Core i7 프로세서.
494 질문 전체 보기
Where can I find the 12+16 SSD logic board connector?
I’m helping a friend revive a MBP Pro 2014 from an accidental spill after sternly admonishing him for being a menace to his MacBook Pro while drinking his juice. Luckily, his data is safe, but several pins on the nameless, proprietary 12+16 SSD connector on the logic board are charred for life. I’m planning on replacing it with a new connector.
I’ve read the connector referred to as "gumstick" on the board schematics. I have conducted extensive searches, but I can't find it listed anywhere as a replacement part. I find it surprising given how easy it is to find other connectors and it's vulnerable location for liquid damage. I did find it on a few PCIe adapters, but the profile doesn't provide enough clearance for the bottom cover.
Any ideas where I should look?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
I found the connector, though not as a discrete part. It turns out the Mac Mini 2014 has a flex cable featuring the 12-16 connector on one of its end:
From the photo, you can see the connector cleverly disguised with some black electrical wrap covering the metal shield plate.
해당 답변은 도움이 되었습니까?
점수 3
댓글 2개:
Not a bad idea! Let us know if it worked.
Works like a champ! Now I have a working MBP machine. Take that Steve Apple!
댓글 달기
You probably won’t find it anywhere new, I’ve never seen it for sale..you’ll have to buy a donor board to find one.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
AppleGuyPie 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 6
30일 전: 12
전체 시간: 442
