주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
Is this display connector broken?
Can anyone tell me if this display connector is looking good?
The display brightness is not working correctly. I use a cheap eBay replacement display so before I order a new one I want to know if this connector looks good.
The 6th pin on the top looks weird to me..
Thanks!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
For me, it's rather difficult to tell by just looking at this picture. Check carefully with tweezers if there is any unstable pins, which features poor contact with board.
It would be better if you have a multimeter to test the diode value of each pin on the connector. If it’s all normal value, then restart with a new display.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Thanks! Will try to use tweezers and/or check with a multimeter.
댓글 달기
가장 유용한 답변
Looks okay, might need to clean up the connector a bit on the 6 pin. 99% isopropyl alcohol and some brushing should get that cleaned.
Otherwise be extremely careful with tweezers / exacto knife to clean that out without damaging the pin.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Thanks for your comment. I've tried cleaning it with IPA two times but that didn't work. I will try to remove it with a tweezer.
댓글 달기
귀하의 답변을 추가하세요
Matthijs 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 2
전체 시간: 46
