주요 콘텐츠로 건너뛰기
모델 A1278, 2012년 6월 출시. Turbo Boost가있는 Intel 프로세서, 최대 512 MB DDR5 비디오 RAM
1624 질문 전체 보기
Keyboard and power button not working
My macbook suddenly had some keys start typing the wrong letters. Now, (a few hours later) none of the keys or the power button are working.
The macbook turns on when I unplug the battery and plug it back in, and the trackpad works fine.
One of the cables is looking a bit stripped too. (see photo)
Is this a logic board issue, keyboard issue or both?
helllllpppp
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 3개
선택된 답변
If the machine has not gotten wet.
The first thing to check is if the keyboard cable is fully inserted into the logic board.
If it looks like it has come out some, use a piece of electrical tape on the cable to pull it into the slot rather than trying to push it in (be sure to release the lock before doing so.
If it has gotten wet you can replace just the keyboard. I’ve posted a video guide for doing that.
See step #11 of this guide MacBook Pro 13" Unibody Mid 2012 Upper Case Replacement
https://www.youtube.com/watch?v=EEs6Nl34...
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
가장 유용한 답변
Keyboard is liquid damaged. Take it to a reputable repair shop to check the MacBook for liquid damage.
Sometimes just need to get keyboard replaced if lucky.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
You should go to someone, and repair the wire. It might be the reason!
Update (02/19/2019)
It also could have been the fact that something spilled on the keyboard, but probably the components and wiring. There is also the fact that it is to old to survive!
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Is there a way I can repair the wire myself?
댓글 달기
귀하의 답변을 추가하세요
Maria 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 3
전체 시간: 82
