Why is washing cycle takes 67 minutes?
Why is washing cycle takes 67 minutes ?
I have 15 apartment in manhattan. only this washing machine takes 107 minutes to just washing.
is there anyway to make it shorter ?
Tomomi Kanamaru
좋은 질문 입니까?
Tomomi Kanamaru
좋은 질문 입니까?
Cause 1
Water Inlet Valve
The water inlet valve opens to allow water to enter the washing machine. If the water inlet valve is defective, the wash may fill slowly or not fill at all. The water inlet valve requires sufficient water pressure to function properly. First, check the water pressure to determine that it is adequate. If the water pressure is adequate, try cleaning the screens inside the water inlet valve hose connection ports. If the washer still fills slowly, replace the water inlet valve.
Cause 2
Low Water Pressure from Central Supply
The home water pressure might be too low. The water inlet valve requires at least 20 psi to function properly. Check the water pressure to the valve to determine if it is sufficient.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 32
