My intel iMac's fans gets louder then usual
got mid 2011 21” imac, i disassembled it all (without removing heatsink), cleaned both fans and motherboard and installed everything back into case. Fans acting as usual on start, but then starts rotating faster, after 1 or 2 minutes. and even more faster and louder if im watching movie. If i close the movie - fans wont get back to normal silent speed(
Any guess? Thanks
Update (02/24/2019)
sensors
좋은 질문 입니까?
댓글 3개
You'll need to monitor what sensor is getting hot so you can address the problem.
Install TG Pro then post the main window so we can see the sensors (often times you need to grow the windows a bit so all the sensors are seen) 기존 질문에 이미지 추가하기
Dan 의
Have you changed your hard drive?
mayer 의
yes i did, i put the new ssd drive, but i did the same thing 2-3 times before with 21" mac with success (yes i know about thermal sensor in 27" macs hdd).. And btw i put back an old HDD and... same thing: fans getting louder and louder...
Ruslan 의
