주요 콘텐츠로 건너뛰기
Photosmart printer introduced in 2009. This printer uses a 4 color printhead that is designed to be removed by the end user. This printer is compatible with current and previous generation cartridges. Uses HP 564 series ink cartridges.
7 질문 전체 보기
printer will not load paper
the pickup wheel does not move when the printer is calling for another sheet of paper and then the load paper light comes on to load paper?? it appears like a gear is not engaging. How do I open the printer to fix this issue?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
I used to work for hp, but been out of that business long enough that I never saw the insides of the Photosmart printers…
you can start here to get hp’s basic instructions… if that video doesn’t help, try looking at a similar problem on a C310a
hope this helps
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Gary McEwen 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 8
전체 시간: 333
