I need to clean the speaker holes
Hi every one, i have one plus 6T, i have spoiled a hot liquid candle wax on it, and i was able to remove the damage from the screen (thanks to the screen protector) now am left with only 3 holes for the speaker to listen from (the rest is blocked with the wax), i have tried to apply some heat from the hair dryer with no luck, what do you think is the best way to solve this issue ?
좋은 질문 입니까?
댓글 1개
Hi Raving,
thank you for your answer, i had tried to do this but it didn’t fix it, even i applied heat using a hair dryer then i used the needle, but the surface area is so small that the wax will be hard again while am trying to apply the push through the needle
Abdullah Al Rawi 의
