주요 콘텐츠로 건너뛰기
2018년 7월 출시, 15" MacBook Pro, 모델 A1989, True Tone 기술 15.4 inch LED-백라이트 화면, TouchID, 및 최대 Core i9 프로세서 여섯 개.
204 질문 전체 보기
Will my touchbar go out?
I dropped my charger on the end of my touchbar and its kind of dead towards the end. Will the whole thing go out before i can get it fixed? How much would this repair cost? Im trying not to press so hard on it or slam the screen down. Everything still works even Siri even though you cant see it.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
Well good news! You don’t need to replace the uppercase at all, you only need to replace the TouchBar its self!
MacBook Pro 15" Retina (Late 2016-2017) Touch Bar Assembly
Its still a big job so you might want to find someone better skilled.
MacBook Pro 15" Retina (Late 2016-2017) Touch Bar Assembly 이미지
상품
$39.99
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Hello,
Shortly : no it shouldn’t break even more. The Touch Bar is attached to the keyboard, so Apple will change the battery, keyboard and Touch Bar (the hole bottom assembly of your Mac actually). This should cost around 600$. From what I see in your photo, and from what you say (it still works), I don’t think paying for a replacement would be a great idea. Wait for your keyboard to get stuck (keys can get stuck easily on these models), and let Apple repair it for free (they repair this issue for free, changing the hole bottom part, so the Touch Bar also).
You can find the keyboard free repair program here : https://www.apple.com/support/keyboard-s...
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
@talerant - I don't see Apple fixing this for free, unless Keja got AppleCare + and they will still charge a fee as it was damaged, not a parts failure even if the keyboard fails at some point, they will argue the keys got damaged at the same point.
댓글 달기
귀하의 답변을 추가하세요
Keja Wynn 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 8
전체 시간: 146
