주요 콘텐츠로 건너뛰기
일반적으로 통합 스크린을 포함하지 않은 이동하지 않는 컴퓨터입니다.
2134 질문 전체 보기
Is this CPU compatible with my motherboard?
Hi, so I’m building a gaming PC and I am purchasing an AMD 2200G Quad Core CPU. I have heard that the motherboard would need to have a BIOS update to use this CPU. Will this CPU be compatible with a MSI B350M Pro VD Plus ''motherboard? Or will it be totally incompatible? I am fine with updating the BIOS as long as I don’t need the kit from AMD to do it.
Thanks in advance!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
선택된 답변
Yes, your processor will be compatible, you should also be able to boot to the BIOS to update it as well, however, it may be unstable, just keep that in mind.
Also, wherever you are buying the motherboard from may be able to assist you with getting the BIOS updated before you receive it, I would send the company an email or phone them to ask if they would be able to assist
해당 답변은 도움이 되었습니까?
점수 1
댓글 3개:
Oops, I meant a B350 Tomahawk. Will it still be compatible?
It's actually compatible - regarding my Answer.
Great! Thanks!
댓글 달기
가장 유용한 답변
Hi,
it is compatible, but if there will be some problem with drivers or “compatibility”, you must update your BIOS, because from manufactory, the MB is ready for 1st and 2nd generation of processors, but processor, which you are going to use, is 3rd generation.
So yes, it is compatible for about 90%
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
So all I have to do is update the BIOS? Also, will the motherboard turn on in order for me to update it, or will I need the kit from AMD?
Yes, just update BIOS, I think, that you must enter to BIOS and you have 90% done, there may be Update Bios option, if not, you have to create USB Update, or use AMD Kit.
댓글 달기
귀하의 답변을 추가하세요
Random _User_101 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 2
전체 시간: 110
