주요 콘텐츠로 건너뛰기
3MB 공유 L3 캐시 2.6 GHz 듀얼-코어 Intel Core i5 프로세서 (Turbo Boost 최대 3.2 GHz). 2013년 2월 13일에 출시되었습니다.
119 질문 전체 보기
MacBook not running off battery after replacement
The battery in my MacBook Pro A1425 was draining fast and had to be charged constantly, so I decided to buy a replacement.
I replaced the battery, it’s recognized by macOS, but it won’t run on battery power, and it says it’s not charging. It only runs with the power cord connected.
I tried to put the old battery back, but it now has the same problem, won’t run of the battery.
So now the new battery is back inside.
Tried resetting SMC a couple of times, but no difference.
This is what coconutBattery tells me.
What is there left to try?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
It’s possible you got a bad battery, I’d try changing it again. Maybe this time from a different vendor.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Any Luck with this ? My A1425 does not recognize the battery after I changed the trackpad. I am getting ready to change the battery considering that it is about 5 yrs old and probably done with the cycles. But just wondering if I might run into this issue since I had no issues with the battery prior to replacing the trackpad.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Nope, no change. I have not tried replacing the battery yet again.
I replaced it with another battery before the one that is currently inside, that one did not work either.
So I have tried two replacement batteries, and the original. And neither of them is charging, or can be run on battery alone.
댓글 달기
귀하의 답변을 추가하세요
Jens 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 113
