주요 콘텐츠로 건너뛰기
Comprehensive set of repair guides for TV consoles manufactured by Sony, from the 1994 PlayStation to the newest PlayStation 5.
4796 질문 전체 보기
Not able to initialize my PS4 for total system reinstall
My PS4 had been having issues updating the software. It has no trouble downloading the install file, but when it tries to restart itself, it shuts down instead.
I have nothing valuable on it so I downloaded the 6.20 update on the Sony website and tried to initialize in safe mode using USB.
That made it worse.
At first, it looked normal. But when it came time to restart the system, it shut itself off again.
Now it’s stuck in safe mode with only “7. Initialize PS4 (Reinstall System Software)” option available, and nothing else. I’m literally unable to select any other option.
Of course, if you select that, you get stuck in the same shutdown problem.
I’m at wit’s end here. The main problem seems to lie with its inability to restart itself. And now the PS4 behaves as if it’s totally bricked.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 14
댓글 10개
Is it properly ventilated?
I need help with my PS4
I installed a brand new hard drive on my PS4 and initialized it. After it initialized it said it was going to download operating system when it restarted. But it keeps restarting in safe mode and will not load the operating system. I think I've tried everything I don't know what to do.
And I used a full update file from PlayStation
Also the power button is not working on the PlayStation 4 I started by turning on the TV and it turns on the PlayStation 4 but the power button does nothing.
댓글 5개 더보기
댓글 달기
답변 8개
가장 유용한 답변
I as well recently been having a very similar issue…
On initial start up of the PS4 I would get a system error indicating “Cannot Start PS4. Connect a controller and press the PS button”. I messed around in Safe Mode multiple times trying the different settings and even after a couple times choosing option #7 “System Initialization” the PS4 would then work properly for about a week before returning to this cycle of errors.
Finally I pulled the hard drive out and plugged it into my desktop PC and it did report some bad sectors, I wiped it and reformatted it (exFAT) and it reported “good” condition but still overall no luck.
Lastly I used a different hard drive entirely and this is where I am stuck. Upon booting into Safe Mode the only option I get is #7 which is a full system initialization. I have verified the correct file I put on the USB key which is the full system file and not just the update file (version 7.51). The PS4 reads the file, asks if I wish to continue because everything will be deleted and I proceed.
1) Step one, it does get to 100% full system initialization.
2) Then proceeds to do a system file update which succeeds (safe mode window)
3) then it displays PS4 graphics screen and does a second system file update and succeeds
4) then it reboots and does a system storage install which actually takes a bit of time to complete.
5) It’s then after it completes the system storage like building the database where it does a final reboot and then it displayed the PS logo but then just sits on a black/dark blue screen. The “blue” system light is continually pulsing if but will just sit there as long as you let it. I have pressed all the buttons and so on only thing left it to turn it off.
Upon turning it back on I get the “checking system storage”, it gets stuck at 24% and then other errors again about not able to start. If I go back into Safe Mode at this point I am back at square one with only option #7 as my choice as if it didn’t actually load anything we just saw as successful.
I will try a brand new store bought drive to eliminate the possibility of a bad drive but after this without dismantling the entire PS4 I have no idea how else to fix this PS4.
해당 답변은 도움이 되었습니까?
점수 5
댓글 7개:
Make sure your using the “complete” installer and not the full installer. It won’t work using the full installer.
UPDATE: installed a brand new hard drive and without any hesitation the system did it's full initialization and booted. Working PS4.
@SpinKing Yes absolutely made sure it was the full system installer and not just update. Thanks! :)
I need help.
I too am having this issue, I done all that … Now am stuck on option 7 in safe mode.. n e 1 out here can offer some pointers.1st ever with these issues for ps4system
댓글 2개 더보기
댓글 달기
So from what you said it sounds like the PS4 can read the update file you’ve put on the USB (assuming it’s the full update one for re-initializing the PS4 and not just updating it) but after it attempt to reboot itself to perform an update it just gets stuck on Safe Mode instead of installing the update.
That is a big indicator of a bad hard drive in most cases. You can take out the hard drive and plug it into a desktop computer (before plugging it in make sure the computer is turned off) if you have one to check the health of the hard drive. You can alternatively plug the 2.5” PS4 hard drive into a portable 2.5” drive enclosure to check the health using the program explained below.
You can use a program called Hard Disk Sentinel which you can download here to check the health of the hard drive.
If it reports bad, weak sectors or data transfer errors or any other relevant health problems the hard drive needs to be replaced + PS4 - re-initialized with new hard drive to fix the problem.
해당 답변은 도움이 되었습니까?
점수 4
댓글 달기
Yeah you have a bad hard drive. So, you need replace your hard drive and then reinstall the system software on to it. Then, your PS4 will be able to start up normally.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
You need to purchase a new hard drive for your PS4 because the one you currently have now is damaged. After you take out the old hard drive and insert the new hard drive, you need to install the latest system software onto a USB drive.
해당 답변은 도움이 되었습니까?
점수 0
댓글 4개:
I have the same issue with new drives and they are even formatted as ex fat so maybe it's the firmware on the nor flash. I know there's a way to dump it. Everything else checks out. The drives good and formatted. The usb is good and formatted with the correct update and I used the usb 3.0 port but still the only option available is reinstall system software.
Any luck both of you? I'm haveing similar problem but mine freezes during system software update. Just bought new hdd and same issue persists.
I have a same issue, i putted new ssd in PS4 and have only option 7. in safe mode. But it's keep telling me issue that update file is corrupted... i tried all possibilities, 5 different usb, formated different, but always stucked in option 7.
Only once i succeed to have all options in Safe mode but every time result is the same... cant upload system file and start PS4 :(
I am experiencing the same issue. Did you manage to fix your problem?
댓글 달기
Try to install the whole software and put it on USB drive formatted as FAT32, be sure that the SSD or the HDD is FAT32 or exFAT file systems and it well work
https://www.playstation.com/en-us/suppor...
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Not sure it will help but in my issue, it won’t start up and only reinstall system software is an option. Only after picking that option, I canceled and went back and forth and after a few times of canceling the initialize option, all the options become available. This only works if you hold the power till the second beep to get to safe mode, not just turning it on and let it start in safe mode as mine does. I figured this out accidentally but it still didn’t help having all options cause nothing worked. Hope this works for someone but it seems this problem we all share is not solvable with our present hard drive…
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Well you can try out the following:
  • Well check your device for any damage.
  • Try a different power cable or outlet.
  • Clean your console.
  • Restart your device in Safe Mode.
  • Try Factory reset your device.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I am in safe mode on my PlayStation 4 I would would chose the option #3 update using a thumb drive it update all the files on there it will get to 100% but, it turns off blue light then turns back on again you will see the black screen PS logo then it will go back to the safe mode again then it go back saying "connect the DualShock 4 using the USB Cable, and then press the PS button". This is the problem I am having I wish I know what to do for a few months now.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
buckyhermit 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 13
7일 전: 117
30일 전: 586
전체 시간: 47,174
