주요 콘텐츠로 건너뛰기
An update released in May 2016 for Razer's 14-inch Blade gaming laptop. The first model in the series to feature a chroma backlit keyboard.
Is there a fix for fan speeed on this model?
Fans run on high from startup. The fix from razer doesn't cover this model. Is there a fix other than sending it in (out of warranty)?
Also, keyboard stopped working. I was able to fix it by reinstalling Windows, but that only worked 2 or 3 times. Now I have to use it in tablet mode.
Is it worth sending in for repair or just cut my losses and get something else?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
선택된 해법
Hi,
about the fan:
Download Fan Control
Download .XLM File
1. Install Notebook Fancontrol
2. Put the Razer Blade.xml file to --> Program Files (x86)\NoteBook FanControl\Configs
3. Start the Program
4. Choose the Pofile
5. Enjoy
If it won’t work, you can check your BIOS and customize them, but it’s on your own risk. The BIOS may include information about FAN and also can control FAN Options - For many times, it’s hidden under: "System Setup" or "Configuration" or some simillar name.
about the keyboad:
Check, if it’s really software problem - Check connection between keyboard and MB, also, check condition of wire.
If it’s really software issue, then:
  • Uninstall keyboard drivers
  • (optional) - uninstall Synapse drivers as well
  • Reboot your notebook
After the reboot, keyboard will boot up and start working as perfect, if not, try this options for a several times.
If nothing worked, there’s time for repair in service.
이 답변이 도움이 되었나요?
점수 3
댓글 2개:
thanks man my problem is solve cheers..
Is there a way to modify the fan curve on the xml file?
댓글 달기
답변을 추가하세요
cmblanco813 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 18
전체 시간: 9,024
