주요 콘텐츠로 건너뛰기
모델 A1502 / 4MB 공유 L3 캐시 2.6 GHz (Turbo Boost 최대 3.1 GHz) 또는 2.8 GHz (Turbo Boost 최대 3.3 GHz) 듀얼-코어 Intel Core i7 프로세서.
494 질문 전체 보기
Cant find hard drive in Disk Utility
Macbook wont boot and hard drive cant be seen in disk utility. Please help
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 7개:
Hey Anthony. The solution could be a number of things. Have you tried entering MacOS recovery already?
Press and hold Command (⌘)-R during startup. Let me know if you're able to enter the recovery suite like this.
-Alex
@tony3000 any luck with that?
I was able to open the disk utility but could not find my hard drive/start up disk
In MacOS Recovery? Or Target Disk Mode? In other words, on the MBP you're having trouble with?
oh opps! now I see where to add a comment. Sorry, new here!
댓글 2개 더보기
댓글 달기
답변 2개
I don’t have an answer, but just last night I attempted to use a trial of CCC and I drag & dropped my HHD from finder to the source box and POOF,
now I have to hunt for it.
Great question & await
Update (05/06/2021)
When you are in Disk Utility
on the top bar: click view,
select “show all devices”
? For years when I was in Disk Utility I never even knew that top bar was up there!!! So many hidden in my face gems…
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
this is the disk utility and my start up disk can’t be found
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Anthony Johnson 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 7
30일 전: 8
전체 시간: 445
