주요 콘텐츠로 건너뛰기
Nintendo가 스위치 시스템용으로 제작한 보다 전통적인 무선 비디오 게임 컨트롤러입니다. 모델 번호: HAC-013.
88 질문 전체 보기
Right stick drifting downwards without input.
My Switch Pro Controller has been working perfectly fine until a few weeks ago, when the right stick has been moving down, making it hard to aim in games and making navigation of the home screen difficult. I am out of warranty and trying to recalibrate the stick has done nothing.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
I’ve had this problem myself, but whenever I sent it to Nintendo, I just kept getting it. So, I just figured out some solutions for myself.
1st (and easiest). Try getting a spray can of “Electrical Contact Cleaner” and just spraying just a little of it into the base of the problematic stick, pushing the stick away from the nozzle head and rotating the stick multiple times to work it in. I think that this mainly fixed the problem for me because the Switch Pro Controller has a major dust/grinding issue with the sticks and this spray is a good and safe way to clean all that dust. It should only take a couple of seconds to dry.
2nd is to open up the controller and replace the sticks entirely. This isn’t nearly as difficult as it sounds. Fortunately, the Pro Controller uses regular Philips head screws, so you just undo all the screws (careful not to lose them!) until you get the front plate off (carefully!), then just pop the sticks off and put some new ones one! You should be able to find some replacement sticks with Google pretty easily, but these metal ones here https://smile.amazon.com/dp/B01M32MP9G/ that include replaceable heads and a tool kit to get into the controller don’t grind dust up like the base model and work just as good. Maybe while you’re still in the controller though, try spraying some electrical contact cleaner (from a safer distance this time) around the board to get some of that dust that has surely accumulated from the sticks.
If that doesn’t fix it, you likely have a malfunctioning joystick component on the controller’s circuit board, and repairing that (while not terribly expensive) requires soldering, which I have no experience with. I hope this helps!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Connor 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 882
