주요 콘텐츠로 건너뛰기
2016년 9월 16일 출시. Model 1660, 1778. GSM 또는 CDMA / 32, 128 또는 256 GB / 로즈 골드, 금색, 은색, 검정색, 칠흑색으로 제공됩니다.
2264 질문 전체 보기
U2710 getting hot, no shorts
We have a board that the U2710 gets really hot. I ordered replacement chips and swapped this power switch component.
Same situation stands, This chip really gets hot, the top half of the board doesn’t appear to heat up at all. VDD_Main draws 3.6V with a DCPS, PP1V8_SDRAM draws 0.450V. NAND lines draw nothing.
I suspect power is getting to this component but not getting through it possible?
Would really appreciate a second opinion on something a bit tricky like this. Thank you!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 4개
Try checking the issue with pp1v8_sdram first as it's to low
Weird, after testing with DCPS, short to VDD_Main came back, was again under U2710, replaced with another and short gone, this happened one more time (10 chips arrived from aliexpress - plenty to test). Seems to get a short when DCPS is on. with a battery this draws 0.01mA. Trying to look at the schematics with ZXW to see where the power should be going.
Thank you for the help so far.
Whenever I have this with a battery, it draws no power really, DCPS causes a constant short in the U2710, I’m thinking it could be something charhing related with a line, or chip, maybe tristar or tigris. Will update this
Try the bb_pmic
댓글 달기
답변 2개
선택된 답변
I managed to sort this one. At first I swapped this U2710 and it made no difference, what did sort it was changing Tristar,
I also changed Tigris before Tristar but that didn’t change anything, so it was a Tristar fault I believe.
Successful case!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
가장 유용한 답변
PP1V8_SDRAM draws 0.450V. Perhaps something down long that line is pulling that line down? Can be capacitors or bad resistor causing this on that same line. It’s probably a partial short which will take some time to find out which one is bad. Try removing caps on that line (Test for resistance on caps to compare resistance to ground) and see how it goes.
해당 답변은 도움이 되었습니까?
점수 3
댓글 1개:
Will give that line a look. Thank you
댓글 달기
귀하의 답변을 추가하세요
Elliot 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 10
전체 시간: 845
