주요 콘텐츠로 건너뛰기
2016년 9월 16일 출시. Model 1660, 1778. GSM 또는 CDMA / 32, 128 또는 256 GB / 로즈 골드, 금색, 은색, 검정색, 칠흑색으로 제공됩니다.
2264 질문 전체 보기
touch id not working after screen replacement
so I replaced the cracked screen of my iPhone 7.
the touch id and home button worked for a little bit of time.
after a while, the phone just turned black, showed a loading icon and turned off.
I turned the phone back on but the touch id and home button stopped working.
i checked connections, tears, and there was no issue. I put the button back on to my old screen and it worked.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
Try a different screen. Often when I have one that does that, it’s just the screen. Each has a flex for that button. Some are cheaper than others. Sounds like all you need is a better screen!
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
If you replace your home button by somewhere other that apple touch ID wont work. So I am assuming that when you replaced the screen you also replaced the home button. The reason is because the home button needs to be paired with the motherboard witch only apple has the ability to do that.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
No, I did not replace the home button as well. just the screen
댓글 달기
귀하의 답변을 추가하세요
pritham 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 2
전체 시간: 51
