주요 콘텐츠로 건너뛰기
Shark Navigator Lift-Away (NV352) is a type of vacuum that functions on both hardwood and carpet with a lift-away feature. The NV352 includes several cleaning attachments. The vacuum was released in 2008 and is often referred to as the Shark Navigator Lift-Away.
10 질문 전체 보기
Why has the roller brush stopped going around?
Why is the roller brush not going around. Could the belt slip off?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 3개
가장 유용한 답변
If your Shark vacuum stops moving suddenly during use, see the Shark ION Robot R75 Stops Moving Unexpectedly problem page for possible problems and solutions.
Use this guide to help diagnose the issue:
Shark NV352 Roller Brush Replacement
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
Because the handle needs to be pulled back and the switch needs to be turned on to BRUSH ROLLER ON.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
broken belt
follow this video
https://www.youtube.com/watch?v=zkDeWuXb...
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Pamela McCarty 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 6
전체 시간: 180
