주요 콘텐츠로 건너뛰기
2015년 3월에 발표, 2015년 4월 10일에 출시된 Galaxy S6은 Galaxy 라인의 다음 주력 제품입니다. 곡선형 스크린 버전은 Galaxy S6 Edge로 알려져 있습니다.
487 질문 전체 보기
Doesn’t Turn on
I have a Samsung Galaxy S6 come in for repair and customer told me they were using it one day and it decided to shut off and not turn on again. They managed to get the battery icon to come up once after unplugging and plugging the cable back in and that was it….. This was back in 2018 when it stopped working and they put it in a drawer for a year until now and brought it in for me to diagnose it
The screen itself is fine (no lcd cracks) and the age of the phone is November 2016….
The charge port is fine because when I hooked up to my USB meter, it’s showing 0.38amps. I know it should be higher but was wondering if a bad battery would cause it to only show that voltage and not charge. Sometimes if you leave the phone plugged in for awhile, it’ll drop to 0amps.
We also tried wireless charging and the phone still does not turn on. Is this a bad battery and what else should I look for?
no water damage and excellent condition
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
Stuck at 0.4A usually points to Power management chip or CPU on the logic board going bad. These tend to be unfixable.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Note sure if you ever got the phone working. I would say it’s mostly likely a battery issue. Leaving the phone in storage with a dead battery can cause damage to the battery. If the battery drops below a certain point, it can do damage and the battery will never charge up again.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Daniel 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 2
전체 시간: 68
