주요 콘텐츠로 건너뛰기
2018년에 출시한 Galaxy J6는 Galaxy J5의 후속 제품입니다.
Touch screen is not working after the update
Recently i changes my J6 display due to crack. Today i recieved the software upate and i updated it.
when the updat finish and phone restarted, the touch screen is not working.
What is the solution ????
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 4개
Did you back up you'r phone before updating?
Nope. i did not expect that
Can you try plugging it into a PC and backing up like that?
how to fix it?
댓글 달기
답변 6개
가장 유용한 답변
Could be a weird bug with the new update. If you can, try factory resetting the phone. You could have also just had unlucky timing and the screen just decided to die on you. Most likely it’s some kind of software issue.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Touch is not working correctly
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Change original display ( combo )
See you your job done.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Hello,
At this point, presumably, you have already got a solution.
Just for the record:
You can connect a usb mouse using an OTG cable to operate the device. For backing up data, you need a bluetooth mouse to operate the device freeing the charging port to connect the phone to a computer.
Then you can enable usb debbuging and oem unlocking and go after a file to patch and fix the actual problem, without having to disassemble your device and avoiding the risk of losing your data.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
The screen is totally off
이 답변이 도움이 되었나요?
점수 0
댓글 달기
There is no Drive app on my device
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
isfaak 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 35
전체 시간: 2,952
