주요 콘텐츠로 건너뛰기
2010년 중반기 모델 A1278 / 2.4 or 2.66 GHz Core 2 Duo 프로세서
794 질문 전체 보기
Is it possible to upgrade MBP 13 mid to Mid-2012 13?
Is it possible to upgrade MBP 2010 mid to the following board below?
Mid-2012 13" - MD101LL/A* - MacBookPro9,2 - A1278 - 2554*
Mid-2012 13" - MD102LL/A - MacBookPro9,2 - A1278 - 2554*
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
The system series in question:
● What you have: MacBookPro7,1 - MacBook Pro 13" Mid-2010
● What you are looking at: MacBookPro9,2 - MacBook Pro 13" Mid-2012
댓글 달기
답변 3개
선택된 답변
Unfortunately the answer is negative, the 2010 model has different connectors on screen and logic board and they don’t match with the i5/i7 boards of 2011 and following years. You’ll have to stick to core2duo boards for compatibility.
해당 답변은 도움이 되었습니까?
점수 3
댓글 5개:
Mostly you need to stick with the same series in your case any of the MacBookPro7,1 logic boards. The architecture of system limits you, these two series are very different as @arbaman stated.
So there is no other way to upgrade the CPU resources right?
The fastest board available for your model is the core 2 duo 2,66Ghz. You can increase RAM and put in a SSD, but that's about it.
RAM is up to 16GB? I am correct?
Yes, you are right, it takes up to 16GB RAM.
댓글 달기
Unfortunately not, the 2010 have different top case bracket for the mother board.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
the 2010 and the 2012 use different cable connections in the logic board and on the screen.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Arnel Arenilla 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 110
