주요 콘텐츠로 건너뛰기
2009년 중반기 모델 A1278 / 2.26 or 2.53 GHz Core 2 Duo 프로세서 EMC 2326
745 질문 전체 보기
MacBook Shows X sign battery, but works off battery
Hello everybody my first post here. here is the story. i got a Macbook mid 2009 A1278 with the 820-2530 Motherboard, i bought it second hand with short battery life, i bought a knock off replacement from a local store. worked but the battery dies unexpected always on 40-50% but kept reading the battery (percent and if there is one), want back to the store and they asked also the computer to see if it really was a battery issue, turned out it was. After a day i called them back and i asked if since the issue is confirmed can i have my macbook back since i was using it for xcode on college and wait till a new high quality replacement battery arrived, they said yes, i got my mac back BUT it was showing an X icon on the battery, no green LED indicator on the side, nothing. excpept when i unplugged the charger(with green light never gets orange) macbook was still getting power even though it reported it has no battery, i was confused plus the LED on side didnt work. so i got a call from the store saying the new battery arrived and i should go there with my laptop to install it. i went and upon plugging the battery i got green light on the charger, no green battery LED status, with the new battery.i boot it up, removed the charger and the mac reported no battery and a green light. the battery was good since they had an A1278 next to me for testing the issue. so:
TLDR
Macbook Shows x sign on the battery, doesnt charge/turn orange, no green led battery LED activity, BUT if it turns on via charger can use battery power with “no battery installed” NVRAM/PRAM and SMC reset was performed multiple times with no changes
(i just hope this is not an SMC issue)
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개:
Lets get a better view of things install this gem of an app CoconutBattery anapest a snapshot of the main window here for us to see 기존 질문에 이미지 추가하기
댓글 달기
답변 1개
uninstall the battery driver
Update (03/14/2019)
ok I believe I know what the problem is, I believe you may have a blown fuse that is for the battery but the fuse for the charger is fine , I had something like this happen to me before on my nintendo dsi XL
I fixed the problem by removing the fuses and creating a solder bridge, so I will look up the fuse locations for this laptop and ill be right back with you
해당 답변은 도움이 되었습니까?
점수 0
댓글 5개:
@fegelein3290 - There is no drivers for batteries in this system so I'm not sure where you are heading here.
LOL , I just read the title
@fegelein3290 - Stick with the same series when you research.
Think it this way ... A jet engine is not the same as a car engine is it? Both need a battery but the design and requirements are very different!
oops sorry I saw something like this with your same model but his one was another link sorry
댓글 달기
귀하의 답변을 추가하세요
Dimitris Serp 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 2
전체 시간: 55
