주요 콘텐츠로 건너뛰기
Apple의 MacBook Pro 노트북 라인은 전문가 및 파워유저를 위한 제품입니다. MacBook Pro 라인은 MacBook Pro 13" Unibody, MacBook Pro 15", MacBook Pro 15" Unibody, MacBook Pro 17" 및 MacBook Pro 17"Unibody를 포함합니다.
20002 질문 전체 보기
820-2936 quarter fan spin
so to start out i dont specialize in mac repair, i mostly work on phones. but a friend of mine had an issue with their macbook so i figured id take a look at it.
so everything is disconnected but the board and dc in board. it shows a green light on the charger and fan starts to spin up then stops. i checked all the main power rails and i found one that isnt right. pp5v_s3 is missing and its weird, when the fan starts to spin it shows 5volts for a split second the 0 again, and if i hook power to the board then disconnect power and test the line is shows as .006 voltage drop in diode mode but if u keep the multimeter probes on it starts to rise until its at like .400 i went over the entire board under a microscope many times and also looked at it with ir camera. i dont see anything that looks terrible. but im stumped and am hoping one of the experts on here can point me in the right direction.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
You’ll need to spend sometime reviewing Louis Rossmann’s YouTube channel as he has documented a few different causes for your problem with a bad pp5v_s3. Get the schematics & board views so you can follow what he does and what trace or component needs to be repaired/replaced.
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
that was step 1...lol
@mobilemedic - Step 2 is not down voting a fair answer!
Your expectation is we can tell you what competent has failed, thats just not humanly possible from afar. If I had your system in front of me I would take the exact steps I outlined to you.
Debugging a board is a process using the documentation and test gear to isolate out the failing component.
댓글 달기
귀하의 답변을 추가하세요
lukerockhill 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 3
전체 시간: 619
