주요 콘텐츠로 건너뛰기
iMac Intel 27" EMC 2309 (Late 2009, Core 2 Duo 3.06 또는 3.33 GHz) ID iMac10,1, EMC 2374 (Late 2009, Core i5 2.66 GHz 또는 Core i7 2.8 GHz) ID iMac11,1
467 질문 전체 보기
Reluctant to start up
My 27” iMac doesn’t want to turn on. Did the usual check of outlet, cord etc. I read somewhere to try unplugging the power for at least 30 seconds. That didn’t work, but I did find that unplugging for several hours did. When on, it seems fine. But if I turn it off, it absolutely will not power back up unless unplugged for an extended time. Does this make any sense? My inclination is to replace the power supply, but am puzzled by why it works okay if I can coax it on. Any feedback appreciated. Thanks.
Update (03/15/2019)
I did replace the pram battery (Apple didn’t make it easy), but this did not correct the problem. As before, will only start up after being unplugged for several hours. When it does turn on, it seems completely normal. It’s as though something has to cool down before restarting. Is there a component in the power supply that would act this way? Any additional suggestions appreciated. Thanks.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
This sounds to me like a cold solder joint on the power supply. Personally I would pull the board and go over the solder joints with a soldering iron and some lead based solder and use a multimeter to test for continuity.
Here’s a video on how to test for a cold joint:
https://www.youtube.com/watch?v=JrcMQb1g...
Here’s one on how to fix it:
https://www.youtube.com/watch?v=VLubdi6a...
iMac Intel 27" EMC 2309 and 2374 Power Supply Replacement
해당 답변은 도움이 되었습니까?
점수 3
댓글 1개:
Thanks for the suggestion. Re -soldering beyond me, so I replaced the power supply. No change. A friend who works only on PCs says the symptoms are 70% power supply, 30% motherboard. Any further thoughts from the Mac community much appreciated.
댓글 달기
Well, it does sound like your PRAM battery needs replacing as the settings are getting lost. We don’t have a guide to get to it directly but this one will get you there iMac 27" Late 2009 Intel Processor Replacement (EMC 2374) on the back side of the logic board you’ll find the PRAM battery
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
mike antonick 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 94
