주요 콘텐츠로 건너뛰기
Apple의 2016년 개정판 노트북은 전문 사용자를 대상으로 제작되었습니다. 15 인치, 2880 x 1800 Retina 화면, 쿼드-코어 Intel Core i7, 256 GB / 512 GB / 1 TB / 2 TB 저장 공간 옵션, 16 GB RAM, 그리고 Touch Bar가 장착 된 키보드가 특징입니다. 2016년 11월 출시되었습니다. 모델 A1707.
260 질문 전체 보기
No Display off boot
Hello all,
I recently acquired this late 2016 MacBook Pro A1707 15” with Touch Bar that was liquid damaged.
The battery was all puffy so I replaced it with an ifixit brand battery but I can not get the computer to boot into recovery or show anything other than the backlight.
I tried to reset SMC and NVRAM but I’m not sure if I did either correctly.
I can’t find the board schematic for this machine either and I don’t know where to go.
PLEASE HELP :(
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
there has been problems with the display cables wearing out over time on the 2016 models
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Like I said I have a backlight, I'm not sure where the display connector is located on the logic board but that could very well be my problem
What's the fix for this problem? If I take the laptop back apart is their a chance that the cable can still be used?
댓글 달기
At this point I think you’ll just need to bite the bullet and replace the logic board. Hopefully the rest of system is OK.
MacBook Pro 15" Retina (Late 2016) 2.6 GHz Logic Board, Radeon Pro 450, with Paired Touch ID Sensor
MacBook Pro 15" Retina (Late 2016) 2.6 GHz Logic Board, Radeon Pro 450, with Paired Touch ID Sensor 이미지
상품
$299.99
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
sev 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 175
