주요 콘텐츠로 건너뛰기
Apple은 2015년 3월 9일에 Retina MacBook 2015 모델 A1534를 4월 10일에 출시한다고 발표하였습니다. 새로운 유니바디 구조 및 업데이트 된 트랙 패드, 키보드, 그리고 Retina 화면을 포함합니다.
281 질문 전체 보기
Re-Installing Mac OS from USB, possible?
Hi there,
Is there anyway of re-installing Mac OS from the USB?
I’m just getting stuck at the please connect the power adapter and with these little delightful things only having a single USB-C port, it’s proving a bit of an issue.
Anyone have any ideas?
Many thanks
Andy
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Didn’t get exactly what’s the problem you have, but the answer to your question is yes, you can surely install the OS from a Usb stick. Having just the USB-C port you’ll likely need an adapter or a USB-C stick. As alternative you can reinstall the OS from the internet booting into the recovery partition if it’s still working. You’ll need to press command+R at boot.
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
Yes, I'm fully aware of both those points.
Maybe I should be a little clearer.
1. I've got Mac OS 10.14 on a USB Stick.
2. Held down alt, booted from said "USB"
3. Reformatted SSD
4. Went to re-install Mac OS.
5. Choose the intended Drive.
6. Message "To Install Mac OS please connect the power source"
7. Ok... where do I connect the power source as there is only the one USB-C Port currently being used to boot from.
Yes I agree. Internet Recovery is my only option, however that will re-install 10.10 and not give me a clean re-install of OS X 10.14.
So my question is, is there a work around to by-pass having to connect the power adaprter and a fully charged battery will hold enough charge to see the installation through.
@andy37429 A small Usb-C dock for the cost 10/15$ normally includes power feed, Usb3 and Hdmi adapters would solve your problem but you'd need to buy one, which depending where you live might be not that handy. Not sure if the install software would allow installing the OS without mains if it finds a fully charged battery that would be more than sufficient to go through the full install with your machine.
댓글 달기
귀하의 답변을 추가하세요
Andy 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 11
전체 시간: 650
