주요 콘텐츠로 건너뛰기
1.4GHz 또는 1.6GHz 프로세서, 64GB 또는 128GB SSD.
162 질문 전체 보기
Black screen and overcooling/heating
Hi guys,
Is there anyone who can tell me what to replace or what to do with my MacBook Air 11” which you can turn on and after not even 5 min the screen goes black and the cooling system starts off very loud.
I went to the Apple Store and they said to replace the logic board… But as you know it is very expensive part.
Is there a cheaper solution to fix or do?
Thanks in advance!!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
If you have the needed tools lets take the battery out. Follow this guide MacBook Air 11" Late 2010 Battery Replacement. Once out, press and hold the power button for a good minute to discharge the logic. Now plug in your MagSafe charger the system should spontaneously start up. Does the system run longer this way? If it does lets install this app CoconutBattery.
Inspect your battery is the top and bottom surfaces flat or do you see a bulge in the middle?
Now with the app installed shutdown the system and re-install your battery. With the MagSafe re-connected lets try starting the system again and quickly run the CoconutBattery App with your phone snap a pic or if you can snap a screen capture of the screen and post it here for us to see 기존 질문에 이미지 추가하기
MacBook Air 11" Late 2010 Battery 이미지
안내서
난이도:
운영
15 minutes
iFixit 이미지
안내서
기존 질문에 이미지 추가하기
난이도:
아주 쉬움
2 - 5 minutes
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Hi Dan,
thanks for your answer and sorry for my late
reply…didnt have much time recently
댓글 달기
귀하의 답변을 추가하세요
Gaetano Baiardi 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 3
전체 시간: 62
