주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
iPhone 6 no cell service
Hi.   I had a iPhone 6.    sometime over Xmas 2018, I took a iOS upgrade to 12.1.2 and I immediately had all sorts of issues with my cellular service.  phone works fine on wifi, but cellular service became non existent.    - when I went to settings, cellular, I didn't have a network selection option to choose.   Reset network settings helped, temporarily, as did a full hard reset.  I also tried backing the upgrade to 12.1.2 out and reverting to 12.1.1.       I have read the reports of phone being bent, re-seating  the cellular antennae etc - I did all those things, and re-seating the antennae.  They all appeared to help.  Temporarily, but  24 hours in, my service vanished again.   Makes me think it was the turning off and turning on that helped temporarly, not the actual actions I took.  I use my phone for my business, so as i’d had the phone several years,  I decided it was time to bite the bullet and change it.
I got myself an iPhone 7, and 3 months in, I had the exact same symptoms - no coverage.    This time, there was no apparent catalyst - no iOS upgrade anywhere near it.  it hadnt been dropped or mishandled in any way 9as far as i can tell).  I was able to take this one back to Apple and they tell me its a known issue (but only with the iPhone 7) and its gone off to be fixed.    It occurs to me, its a very similar issue to the one my 6 had, so if apple can fix the 7, presumably I can fix the 6.
Does anyone know what this known issue is so I can fix my iPhone 6.   (my 6 has had all kinds of new (non original) parts (battery(x2) , screen, BT &  wifi antennae, but all many many months ago) , so there is no chance apple will look  at it.
Any ideas where I should look?
Thanks in advance.
Craig
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 3개
If the same problem appeared on two devices, and a factory reset didn’t help with the first one, then it seems that the problem is originating from your cellular network provider. I would call their customer support line because they should know that you have been paying for cellular network service, but have not been receiving any.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
It is a known issue with the Baseband IC on the logic board, this is not a DIY repair. There are professionals that do this kind of work but it will likely cost about as much as buying another iPhone 6.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Thanks. Agree on the known issue - my 7just came back from apple with a new logic board. I guess I’m not fixing the 6.
Thanks for for the advice.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
craig 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 72
