주요 콘텐츠로 건너뛰기
2015년 9월 25일 출시. Model A1688/A1633. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
2690 질문 전체 보기
iPhone 6S half backlight need solution
I got device which was having no backlight at all , after diagnosis I found the filter capacitor was Burnt instead of changing the capacitor with new one , I did direct jumper , this cause backlight came but the half side of lcd , how to get other half backlight of iPhone 6S
should I put the capacitor on , or change the backlight ic ?
Please share the solution I and Save the phone , as this is my first quation to the forum , please guide me, thank you .
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 2개
선택된 답변
There is no way to tell for sure without testing where the problem is. Backlight is brought to screen with one anode and two cathods. Each line protects the board with one filter, which is there to shield the backlight driver and components. Sometimes damage is limited to the filter, other times it goes further. Bridging a filter is a bad idea as any injury to the screen next time will likely directly destroy the backlight driver, capacitors, inductors and so on.
You can try replace all filters, if backlight is still half faulty you’ll have to dig deeper in the circuit.
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
i change one capacitor , could you tell us which is another filter capacitor of backlight
@doctorgadget You'll have to replace FL4211, FL4212, FL4213 or make jumpers for testing purposes. They're not capacitors though, they're ferrite beads. If you were to bridge a capacitor all you would get would be a shorted to ground line.
댓글 달기
I would recommend you to replace the entire screen.iPhone 6s Screen iPhone 6s Screen Replacement
iPhone 6s Screen 이미지
상품
iPhone 6s Screen
$59.99
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Ajit Sable 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 2
전체 시간: 668
