주요 콘텐츠로 건너뛰기
2.2, 2.4, 2.5, 또는 2.6 GHz Core 2 Duo 프로세서
759 질문 전체 보기
질문 마감됨
Trackpad replacement?
Is it possible to replace a trackpad? Or repair an oversensitive trackpad on the computer? If so is it very difficult?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 3개
선택된 답변
iFixit sells a replacement trackpad with the upper case: MacBook Pro 15" (Model A1226) Upper Case
It is listed as "moderate" difficulty. In my experience, if you are careful and take your time, sort screws as you remove them, you'll be fine.
Cheers!
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Unfortunately, the trackpad itself is not replaceable, so Push Eject's advice is the best that can be done.
댓글 달기
This may be a bit simplistic but try going into your System Preferences - Hardware - Trackpad and adjust the tracking speed and scrolling speed. Easy to do and very cheap.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Hi,I was wondering,if there is a chance to replace a TopCase along with a trackpad from my Macbook Pro A1226(late 2007) for a newer Trackpad from a 2008 model (Last before Unibody models) . I really want to have that "inertial scroll" which the upper model has,and mine (late 2007) doesn't. Any chance?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 14,961
