주요 콘텐츠로 건너뛰기
A1418 / EMC 2833 / Late 2015 / 3.1 GHz Core i5 또는 3.3GHz Core i7 프로세서. 2015년 10월 13일 출시.
96 질문 전체 보기
Possible to replace glue with magnets?
Older iMacs had magnets to keep the screen in place. Wouldn’t it be possible add magnets to the newer iMacs which have the screen glued on? So that when you have to open your iMac the first time, you do not glue it back together but glue in some magnets and some metal and simply snap the screen back in place?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
Nope, there’s no room. The earlier iMacs has room for a metal plate all around the display and room for magnetic pins. This one does not have the room nor thickness to alter it.
해당 답변은 도움이 되었습니까?
점수 3
댓글 2개:
I would love Apple to go back to the magnets. Sadly as @mayer stated just not possible.
Too bad. I hoped for the newer, modern neodym magnets.
댓글 달기
What about magnetic tape?
https://www.amazon.com/Flexible-Magnetic...
I have not tried this myself but I will probably try it next time I have to open up one of these iMacs. Although honestly, I try very hard to not bother. The main thing people want is a larger/faster hard drive and it’s better to use an external (in most cases an SSD) rather than going through the hassle of messing with cutting then replying adhesive.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Skeeve 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 8
전체 시간: 673
