주요 콘텐츠로 건너뛰기
Model A1311 / Late 2009 / 3.06 or 3.33 GHz Core 2 Duo 프로세서
310 질문 전체 보기
iMac 21.5" 2009 Backlight/Brightness issue
Hello, My name is Rod.
I’m a Mac technician and I’ve been having some issues with an iMac 21.5” 2009.
The main issue is that the brightness/backlight at first came and went randomly. Sometimes I unplugged the power cable for several minutes and then when turned on the iMac the brightness/backlight came on.
But for example, if the iMac went to sleep mode sometimes the backlight simply didn´t came back on again.
So I proceded to replace the inverter board. That actually solved the problem for like a week or so. Now the problem is worse since there’s no backlight at all not even when I unplugged the power cable for a day or two. So I proceded to replace de flex cable that connects the inverter board to the LCD, no luck. Still no backlight.
But if a take my iPhone “flash” and put it right in front of the LCD I can actually see the image of the system in the background. So that means it’s not an LCD or video card problem. I managed to pinpoint the cursor using the iPhone flash technique and went to brightness options and turned the bar all the way up. No luck.
So, is there something else that could be causing the backlight problem?
Any suggestions? I look forward for any help.
Thanks in advance.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
I’d replace the LED driver board:
iMac Intel 21.5" EMC 2308 LED Driver Board Replacement
해당 답변은 도움이 되었습니까?
점수 4
댓글 2개:
Thank you for your answer. That's the one I already replaced. Just in Apple's replacement guide is called "inverter" board.
Yes, the Apple Tech writer messed up ;-}
◆ CCFL's use Inverters
◆ LED's use Drivers
A different technology and voltages.
댓글 달기
귀하의 답변을 추가하세요
Rod Requena 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 3
전체 시간: 261
