주요 콘텐츠로 건너뛰기
The Acer Aspire R5-571T-59DC is a convertible laptop-to-tablet PC released June 2016.
8 질문 전체 보기
Laptop blue screened shut down then said no bootable device
So, my Acer Aspire R15 blue screened and shut down. Then it booted itself back up and said no bootable device. I hard shut it down by pressing and holding the power button, waited 60 seconds and turned it back on and again it said no bootable device. I shut it down again and unplugged the charger then started it again and it booted just fine. It's up and running just fine. Now when I plug the charger in my screen goes black with the backlight on. Can anyone tell me what's going on? Is my charger bad?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개:
Hi @jessibee
I would suggest you to test your hard disk first, sometimes faulty harddisk can crash and stall the boot
댓글 달기
답변 1개
That's probably a hard drive issue. That's the small metal moving part in your laptop. It stores all of the data including the software to launch whatever OS you're running. You should probably go to a repair shop to be sure that that's the issue because if it's not it's most likely an issue with the
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Jessie 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 5
전체 시간: 417
