주요 콘텐츠로 건너뛰기
Wheeled toy quadcopter contraption.
7 질문 전체 보기
My battery is not charging
Hi,
I bought a parrot rolling spider a few years ago. Now I found it again, but while trying to charge, I realised it didn’t charge… I looked for tutorials online but nothing worked… I also tried to plug the drone in and than add the battery also with no luck…
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
Did you notice you battery getting weaker? If so this makes sense these batteries are not so grand and look for a battery replacement.
해당 답변은 도움이 되었습니까?
점수 1
댓글 3개:
I just ordered a new battery... Thanks for your quick response!! You are the best!
Where did you get the battery from
Where did you get the battery from?
댓글 달기
How much old your battery is?
해당 답변은 도움이 되었습니까?
점수 1
댓글 6개:
I'm not sure but I just ordered a new one thanks!
He rote in the description a few years
Where did u get the battery from
For srinivassai31 and others concerned; you can likely still charge an old battery. They get reluctant after sitting unused, but take it out, free of all contact, and very slow charge it for a long time. It might pump up just from that, but coaxing it along by repeating this with a little more volts each time..no more than half again its own volts, (=1½) to max at ¾ more added, will almost always get an old dead battery started again. Just watch the heat, and any swelling as signs you need to back off for awhile. Remember this is a percentage, and the smaller the battery the less added volts in a charge it can take. As example: a 12v regularly charges at 17.5v, which is half again its own volts.
Hi, I bought the drone in 2016 and hardly used it for last few years. Now I have found that the battery has swollen. Please guide me how can I replace the battery.
Please note I am in India.
댓글 1개 더보기
댓글 달기
귀하의 답변을 추가하세요
Maximilian Klein 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 19
전체 시간: 2,610
