주요 콘텐츠로 건너뛰기
A1708 / EMC 3071—2016년 11월 출시, 이 MacBook Pro 13”는 OLED Touch Bar를 소개합니다. 듀얼-코어 "Skylake" Intel Core i5 CPU 및 Thunderbolt 3 포트 4 개 포함.
239 질문 전체 보기
Broken touch bar not working replace or any options for repairing
How to repair the Touch Bar when half of it is not working (display & touch) and the rest is working,
What would be the price for replacing or is there any option that could make the rest of the touch bar to work. It was due to accidental damage.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
The Touch Bar display is damaged! There is nothing you can do to patch this together.
You’ll need to either have the Touch Bar replaced or do it your self. Are you up to it and have the needed tools?
We don’t have a guide to do it but the teardown offers enough information to figure things out.
Here’s the needed part: MacBook Pro 13" Retina (Late 2016-2017) Touch Bar Assembly
Or replace the full uppercase MacBook Pro 13" Retina (Touch Bar, Late 2016-2017) Upper Case
MacBook Pro 13" Retina (Late 2016-2017) Touch Bar Assembly 이미지
상품
$54.99
MacBook Pro 13" Retina (Touch Bar, Late 2016-2017) Upper Case 이미지
상품
$209.99
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
Thanks for your kind info i have a doubt that, does changing the touch bar alone could cause any issues later or is it better to change the total uppercase....!!!
It comes down to your skills and if the keyboard is having problems.
댓글 달기
It has also been broken for me and they have asked me € 700 to fix it.  It cost me 2400 and you expect me to pay only € 700 for that ... shameful.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Yes! It's an expensive repair by Apple! If you are handy, while still a bit of work you could replace the touch bar part as I recommended above Vs what Apple does which is replace the entire uppercase as an example 13" MacBook Pro Top Case/Bat/TP UK - Silver, Apple P/N B661-07951 The letter B signifies the UK version of the part.
댓글 달기
귀하의 답변을 추가하세요
ram 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 555
