주요 콘텐츠로 건너뛰기
The HP Envy 7640 is an all-in-one inkjet printer with a built-in scanner and faxing capabilities. It can be connected to your devices via Internet, WiFi, or a USB cable.
20 질문 전체 보기
Is it possible to improve, lubricate or replace the scaner roller
I’ve had the HP Envy 7640 all-in-one printer for a little over a year. I am wondering if there’s any way to lubricate, improve, repair or replace the roller located in the document feeder? I guess I’m asking if this is possible.. Much like you lubricate the roller-shredder on a paper shredder - using either the pre-lubricated paper sheets or the oil itself.. Thank you.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
If the paper is not being pulled into the scanner from the document feeder then it is probably dirty rollers. You can use rubbing alcohol on a lint free cloth to clean the rollers. You do not need to lubricate the rollers.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Matthew Palmieri 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 13
전체 시간: 881
