주요 콘텐츠로 건너뛰기
Samsung's entry level Android tablets. First introduced in 2014.
115 질문 전체 보기
The Difference between a SM-T377P and SM-T377A
So I am trying to order parts for a Samsung Galaxy Tab E SM-T377P (digitizer glass and USB charging port) but can only find the parts for the SM-T377A. I am Fairly sure that the only difference between the two is the Network carrier (SM-T377P=Sprint/SM-T377A=AT&T) but wanted to make sure that there is not a small hardware difference I am overlooking . Thanks for the help Bros / Female Bros
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Both parts are available on ebay and work on different model numbers of the tab e. The port is probably the same as it's soldered to the
해당 답변은 도움이 되었습니까?
점수 3
댓글 3개:
logic board.
Yea I wrote motherboard but it takes parts off some of my answers for some reason
So just I am understanding correctly, the only difference is the number that indicates what carrier that sells it. but the hardware is the same and are interchangable? Thank you for your help.
댓글 달기
귀하의 답변을 추가하세요
Zach Miller 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 6
전체 시간: 741
