주요 콘텐츠로 건너뛰기
GM 소유 Hummer/허머가 디자인한 SUV 및 트럭 수리 안내서 및 지원.
28 질문 전체 보기
I have a Hummer Truck starting to blow heavy white smoke from tailpipe
My Hummer truck has just started blowing heavy white smoke from the tail pipe only when I crank it. Doesn’t blow smoke going down the road. Doesn’t leak anything. The smoke kind of smells like oil or rubber burning. Stinks. Burns eyes. My temperature gauge has been increasing a little. It now reads about 210 consistently. Any ideas?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
From the details that you have given the problem is either a blown head gasket or a blown head. THIS SHOULD BE REPAIRED IMMEDIATELY! This is caused by coolant getting into the cylinder and coolant being burned. That is why it is a very chemically smell and burns the eyes. I would suggest taking the vehicle to your local mechanic and they can do the repair. This repair should only be done by someone that knows what he is doing.
해당 답변은 도움이 되었습니까?
점수 2
댓글 8개:
I would check the oil levels as a clue. You may need a ring job if the gaskets are OK.
@thefluffyfist Thank you. I will have this checked out immediately.
@Dan - I checked oil. Looks good. No milky color. Thank you
@lisa35555 - Water in the oil will make it milky that would be your head gasket, loss of oil would point to the rings, but it may take a while to burn enough to be noticeable.
@danj Checked the oil. Not milky at all. No loss of oil. Nothing is leaking - to the ground anyway. Thank you!
@lisa35555 - The oil won't be dripping to the ground from failing rings. The ring seals the piston and the pistons wall. Here's a good vid explaining things Piston Rings & Blowby - Explained
댓글 3개 더보기
댓글 달기
The things to check to verify the above suggestions for repair would be your coolant level. Check it when the vehicle is cold and see if it is lower then it should be and if it is getting lower. Also pull the oil fill cap and look on the inside of the cap, is there any milky buildup? If so you are getting coolant in your oil.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
@zchead I will do this. Thank you!
댓글 달기
귀하의 답변을 추가하세요
Lisa L 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 11
30일 전: 31
전체 시간: 628
