주요 콘텐츠로 건너뛰기
기기 수리 작업 관련 기술에 대하여 알아보십시오.
87 질문 전체 보기
Non-ESD mat, used with a ESD mat.
I recently bought a silicone soldering mat that has notches and grooves and it really helps with organizing my work space during projects (mostly phone repairs) . But I did some research on the mat and found out it was not ESD safe. So, my questions is that if I did buy a ESD safe mat, would it be okay to use the non-ESD safe mat on top of it.
In other words, ESD safe mat on the bottom, and silicone non-ESD on top. Would there be any static electricity generated.
Thanks, for the help. New.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 1개
가장 유용한 답변
Sadly you still run a risk even when you have an antistatic mat under it.
As an example if you take a ballon and rub it on some cloth so it builds a static charge. The charge is strongest at the location where you rubbed.
Why don’t you use some anti-static spray on it before you use it to be safe.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Juan Lopez 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 13
전체 시간: 295
