주요 콘텐츠로 건너뛰기
3MB 공유 L3 캐시 1.8GHz 듀얼-코어 Intel Core i5 (Turbo Boost 최대 2.8GHz)
371 질문 전체 보기
Can I mount a Samsung 970 EVO PLUS?
Hello, I have a Samsung 970 EVO PLUS m2 drive and I’d lik to know if a compatible adapter exists for my Mac! I already tried this but i can’t connect the ssd to it
https://m.imgur.com/gallery/buQOeYi
Any clues? Thanks
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
Sadly on this specific model there are no good solutions as all the Toshiba SSDs go bad on the mid 2012 airs.
I would install either the OWC or Transcend SSD instead.
댓글 달기
답변 1개
선택된 답변
Your MacBook Air uses a custom Apple connector system. M.2 SSD’s won’t fit directly and I don’t recommend using M.2 adapters as I’ve had to replace quite a few setups with the correct SSD as the M.2 SSD tend to burn out from the heavy CRC errors they encounter in this config. Yes, they look like they work but over time they fail!
You also have a second issue here which is what the system can support for a SSD. There are three different interfaces
Lets review what your system uses here The Ultimate Guide to Apple’s Proprietary SSDs - Gen 2 So your system only uses the Red mSATA interface on the left.
So the Samsung970 EVO Plus is just not compatible!
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
so which ssd you recommend for upgrading a macbook air 2017 (A1466)?
I would go with either OWC or Transcend SSD's or stick with a larger Apple SSD BeetsTech
댓글 달기
귀하의 답변을 추가하세요
tyronefromhell 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 10
전체 시간: 3,940
