주요 콘텐츠로 건너뛰기
Features Bluetooth connectivity, hands-free calls, and control of certain apps through the receiver.
Sony MEX-N5100BT lässt sich nicht einschalten? Keine Anzeige.
+12V an roter + gelber Leitung bis Eingangsdrossel/-Elko und Q805.
Ausgansseite von Q805 +1,2V anstatt +9,1V.
IC803 (BD49100RFS-E2) steuert Leistungs MOSFET Q805 nicht an?
Hat wer Infos über die Funktion von IC803 (BD49100RFS-E2)?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
nein, trotz anliegender Spannung und drücken der Source/off-Taste passiert nichts.
Gibt es in dem Gerät ein ERROR-Signal von einem Baustein welches alles (IC803, Q805) sperrt?
댓글 달기
답변 2개
선택된 해법
Thanks - i Connected 12v , sicher and permanent. Power plus and minus do come to the entlang capacitor (470uF, the bis one) But Not an further.
The sabilized 9.1v for the Display Do Not exist (1.2v)
I substituted the 9.1v for the Display froh externe - nothing changed……. :-)
Someone Has got a sugestion?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
As someone else said, you need to verify 12v at you constant and accessory wire. So you should verify ground. Fake a little bit so you can not quote me on that.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
rboer 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 3
전체 시간: 297
