주요 콘텐츠로 건너뛰기
Repair information for the 7" Android tablet by Samsung. Fixing this device is straightforward, and requires only common tools. The Samsung Galaxy Tab is an Android-based tablet computer produced by Samsung. The 7-inch Samsung Galaxy Tab is the first model in the series. It was introduced on September 2, 2010
112 질문 전체 보기
does not boot up to desktop only black screen showing "samsung"
When I try to turn on the tab, it goes through the welcome screen only to end up stuck on a black screen showing "samung". I tried to do a reboot using the volume and power button with no luck.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 5개
가장 유용한 답변
Try to go to recovery mode by putting off the tab then press power and up volume together. Fromthere go to factory reset.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
I had this problem too. Only a Factory Reset solved the problem temporarely...
Next time I restarted the device it had the same problem. I even reflashed it several times to figure out the problem. Must be something wrong with the stock bootloader. You should send it in. I will do that as well.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
same problem here.
Update
but are you sure sending it is is the only option??
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Should not be the only option but the easiest and fastest way.
You can easily reclaim your money or get a new device since this is a major problem not easily to be fixed by the ordinary user.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
But after a long dat trying i fix my tablet. By using galaxytabhacks.com. by using ons of the new roms IT runs on a 1.4 ghz dualcore. Sweet!!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Robin 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 3,441
