주요 콘텐츠로 건너뛰기
Wi-Fi only version of Apple's 2nd generation iPad Air. Model A1566.
214 질문 전체 보기
Trouble after battery replacement
After replacing the battery, when it starts up, the battery capacity is 1%, and an icon pointing to the Lightning cable is displayed. If the cable is disconnected and started after charging is complete, it will be 1% as well. What should I do now.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 4개
You damaged the motherboard. There's a little transistor (RV3C002UN) near the charging port which functions as a sort of "fuel gauge" for the battery. You damaged or removed that transistor during your repair. Can be replaced via microsoldering.
Specifically, please tell me what to do.
Please.
Find a service (either locally or mail-in) that provides microsoldering repair for your iPad; try ipadrehab.com for starters. Microsoldering requires specialized equipment and training/practice; it's not something that people can do on their own at home.
Thank you for the valuable information.
댓글 달기
답변 1개
선택된 답변
Did you get the battery from IFIXIT because this can happen with a bad quality battery.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Shigeaki Niikura 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 73
